LabVIEW Interface for Arduino Discussions
pH probe>>pH stamp >>arduino>>LabView
Hi guys
I have constructed a pH meter using a pH stamp and Duemilanove arduino. I want to send those pH readings to Labview. it is in serial rite? I havent seen any pH interface in Labview. so how do i do this?
I have installed all the required arduino Labview interface toolkit and i even tried th simple LED example. i got that......But what do i do next???
(5,775 Views)
Because the PH Stamp has a RS232 interface you can not use the LIFA tool kit with it.  See:
<http://dlnmh9ip6v2uc.cloudfront.net/datasheets/Sensors/Biometric/pHStampdatasheet341.pdf>
But what you can do is use your Duemilanove as a USB to RS232 converter and the serial interface capability of Labview to interface your Duemilanove to your PC.  I suggest you use the "Advanced Serial Write and Read.VI" that comes with Labview as a starting point for building a Labview program to work with your PH Stamp.
There is one hidded gotcha.  When you iniially connect Labview to your Duemilanove it resets the Duemilanove and the Duemilanove for approximately 2 seconds ignors all commnds sent to it.  This mens afer you start your VI running you need to wait 2 seconds before yousend a command to the Duemilanove.
hrh1818
(4,201 Views)
thanks man.
i got it working. but like u said i got some 1 or 2 second delay. my reading on the LCD is 2 second slower than on the labview. Is that normal? what should i do?
another thing is that, how do i change that interface into graph? can it be done?
http://imageshack.us/photo/my-images/812/advancedserialvisetting.jpg/
(4,201 Views)
Yes, you can either add a chart or repalce the text box with a chart. Get a Waveform Chart from the following location.  Controls Palette > Modern > Graph > Waveform Chart and place it on your front panel.  You will also need a "fract/Exp - String to Number" block to convert an Ascii string to a double for use with the chart.
Get it here > Functions Palette > Programming > String > String/Number Conversions > fract/Exp - String to number
The 1 to 2 second LCD display delay you are seeing is different than what I was referring to.   I would need to see your swketch before I could trouble shoot that question.
hrh1818
(4,201 Views)
I am just starting to use Labview. can i simply modify the VI file that i attached? so that i can put on the graphs and other stuff. Or is there any other simpler VI that i can work with?
sorry I dunno how to attach stuff, but here's the links
VI file : http://www.filedropper.com/202309
picture: http://www.filedropper.com/advancedserialvisettinganderrors
pH meter sketch: http://www.filedropper.com/phmetersketch
(4,201 Views)
Atttached is a version of Advanced Serial Write and Read showing how easy it is to add a Waveform Chart.  So yes you can add other goodies to the Advanced Serial Write and Read.VI,  I will try to answer the question about he LCD display delay this weekend.
hrh1818
(4,201 Views)
