LabVIEW Interface for Arduino Discussions
ph sensor kit
I am a student who learns the LabVIEW 2014.
Using LabVIEW program, I'd like to measure the pH levels and grid graph.
So, I bought the ph sensor kit(https://www.sparkfun.com/products/10972)
I started to connect with Arduino UNO and ph sensor. and I sketched the sample code.
But, it looks like never work. Just blinking cyan and green lights.
I am a beginner so I barely know what I have to do.
I'd like some example labview codes.
Please, help me what should I do..
(5,503 Views)
The existing versions of LIFA and LINX are not compatible with the Arduino sketch supplied by Atlas scientific.  The Atlas Scientific sketch uses a second serial port on an Arduino Uno.  There is no support in LIFA or LINX to write to or read from a second Arduino serial port.  If you need to use Labview use the Continuous Serial Write and Read VI that comes with Laview to communicate with the Arduino sketch supplied by Atlas Scientific.
However, before using Labview make sure you can  use the Arduino IDE serial monitor and the Atlas Scientific sketch to read valid data from a PH sensor.
hrh212
(4,756 Views)
Have you tryed using LiNX and running the sensor in I2C mode?
(4,756 Views)
