LabVIEW Interface for Arduino Discussions
problem installing
i've also attached the error code for anyone who can't read it.
Anyone know of ways around this error?
Or ever seen this error when d/n the labview interface?
(7,538 Views)
Sorry for the badly shown message.
Just a little back story I am trying to download labview for arduino.  I downloaded the package manager and got the error shown above if anyone has seen this beforeplease let me know.
Caleb
(5,249 Views)
(5,249 Views)
Also remember that you should NOT be using the 64-bit version of LabVIEW.
You should consider using LINX instead since LIFA is old and outdated.
(5,249 Views)
Why is this?
Are you saying they still support the 32-bit?
(5,249 Views)
64-bit LabVIEW does not support many modules. One of the very few things that it supports is vision. So, unless you are doing a very significant vision project that requires excessive amounts of memory, you should be using the 32-bit version.
In the case of LIFA and LINX, you can only use the 32-bit verison (as far as I know).
(5,249 Views)
