LabVIEW Interface for Arduino Discussions
regd: interfacing MCP4901 with lab view using LIFA
I tried interfacing with MCP4901 8 bit DAC with arduino using LIFA tool , but it is not working any suggestion , please.  i attached the file .
- prag
(4,985 Views)
Hey Prag,
What behavior are you seeing when you run the VI? Are you not getting any data back? Not the correct data? Error messages?  I took a look at the VI and everything seems to be set up correctly.
Kevin Fort
Principal Software Engineer
NI
(4,274 Views)
if i run this VI i will get data all clocks and data and CS signal coming in the pins of Arduino UNO perfectly . no error messages
-- prag
(4,274 Views)
Hey Prag,
If all that is working what aspect of your design are you having issues with?
Kevin Fort
NI
(4,274 Views)
all looks fine but no output from DAC4901 , may be i am missing some byte order ,i need to check the datasheet fully .
(4,274 Views)
Hey Prag,
after the spi read/write vi you must generate a load DAC impulse (see datasheet on page 7).
(4,274 Views)
