LabVIEW Interface for Arduino Discussions
solenoid valve using labview and arduino
I am new to lapview . I'm trying to make a program to control a pneumatic robotic arm for pick and place using 3 solenoid valves to control 2 pistons and pneumatic motor which is connected to rotary encoder . the idea is to control arm to rotate from 0 to 90 degrees to pick and place and object .. anyhelp?!
(3,754 Views)
So, what exactly is your LabVIEW question?
(3,676 Views)
Thanks for your reply, First
Is there anyway to take reading from rotary encoder on labview without using NI my Rio or anydevice meanwhile the encoder is connected to arduino ?!
Another thing  .. if i want to activate the pistons to work one after the other with one switch how can i do that?!
(3,668 Views)
