LabVIEW Interface for Arduino Discussions
stepper control with Arduino Mega and LabVIEW
Hi
I have a problem with Arduino
I create a shift register with variable speed by wait ms function and with 4 output
when run it on computer its work perfect and with high speed but when connect it with Arduino Mega its speed slow down and can not run the motor connect at 4 output pin
note I made the same code and it work perfect with My-RIO and run the motor
what is the problem ????????
Message 1 of 8
(6,414 Views)
Communication with Arduino from any application is extremely slow compared to running code on a myRIO.  You will not be able to run a stepper motor at reasonable speed directly from LabVIEW via an Arduino (directly setting digital pins).  The only way to do it with an Arduino is to have code on the Arduino controlling the actual stepper motor.
Message 2 of 8
(5,639 Views)
Thanks to you to your reply
Then there is no method to run the stepper with labVIEW and Arduino ???
Message 3 of 8
(5,639 Views)
You can but you have to implement the stepper controller code on the
Arduino and then send command to the stepper code. Many people use existing
libraries for the Arduino on the Arduino side.
Message 4 of 8
(5,639 Views)
Do you have an example to understand how to do it ???
Message 5 of 8
(5,639 Views)
What stepper motor driver are you using to connect an Arduino Mega to a stepper motor?   Are you using a Unipolar or is it a Bipolar stepper motor?
hrh212
Message 6 of 8
(5,639 Views)
We use L298 module working as H-Bridge for two dc motor and
Also as stepper driver allowing four directions for current flow.
driver in this link http://www.geeetech.com/wiki/index.php/L298N_Motor_Driver_Board
and the motor 12 v Bipolar stepper motor of (350mA) current.
Message 7 of 8
(5,639 Views)
The"Documents" section for this community +contains a "L298 Stepper Driver:" example.  The example does not use LIFA. Instead it uses a VI to send commands to an Arduino sketch,  However, the links shown in the documentation no longer work.
hrh212
Message 8 of 8
(5,639 Views)
