LabVIEW Interface for Arduino Discussions
stepper motor # of steps - 32767
Hello, Im running LIFA stepper motor example on an easy driver. When I run the motor , the maximum number of steps I can give is 32767. Any higher number , and the VI would automatically change it to this. I did some searching and saw that's because of 'closed loop stepper control'. I haven't got an idea what this is and would really appreciate if someone can give me an idea as to what I should do to fix it.
Thank you
(6,576 Views)
The "# of Steps to Move" input is a 16-bit signed integer so has a max value of 32767. This is simply the result of an early design decision for the Stepper Write VI.
There isn't a technical reason why you can't modify the VI and the firmware to both pass and accept and larger value. You'd need to split a 32-bit number into 4 bytes and pass those into the Send Receive VI. Then modify the Arduino firmware to reconstruct the 32-bit number on the other side.
Have fun!
Fred Visser -- SystemLink R&D -- National Instruments
(5,609 Views)
Thank you Fred. But I do not have much of an idea how to do it. Could you possibly explain it more or point me to any helpful resource.Thanks again !!
(5,609 Views)
I haven't tested this in the slightest, but I'll illustrate what I was describing before.
First, modify the Stepper Write VI to move the Set Acceleration control to the inputs below the Stepper # control (eventual command arrary indexes 5 & 6).
Second, change the # of Steps to Move control to a I32 representation, split it into 4 bytes, and wire to the next four array inputs (eventual command array indexes 7, 8, 9, & 10)
Third, change the AccelStepper_Write function (within <vi.lib>LabVIEW Interface for Arduino\Firmware\LIFA_Base\LabVIEWInterface.ino) to expect a 32-bit value for Steps to Move:
// Stepper Functions
#ifdef STEPPER_SUPPORT
void AccelStepper_Write(unsigned char command[]){
    //int steps = 0;
    long steps = 0;
    int step_speed = 0;
    int acceleration = 0;
    //Speed is a 16 bit value, split for data transfer. Reassemble 2 bytes to an int 16
    //Steps is a 32 bit value, split for data transfer. Reassemble 4 bytes to an int 32
    //steps = (int)(command[5] << 8) + command[6];
    steps = ((long)command [7] << 24) | ((long)command [8] << 16) | ((long)command [9] << 8) | ((long)command [10]);
    step_speed = (int)(command[2] << 8) + command[3];
    //acceleration = (int)(command[7] << 8) + command[8];
    acceleration = (int)(command[5] << 8) + command[6];
    steppers[command[4]].setMaxSpeed(step_speed);
Good luck!
(5,609 Views)
Thanks a lot Fred. I'll try this out !!
(5,609 Views)
