LabVIEW Interface for Arduino Discussions
using arduino with labview
Hi:smileyhappy:
i want to use my arduino uno with Labview,
i just need the arduino to send 5 volt pulses of X sec every Y sec
how can i do it via labview?
thank you
(5,578 Views)
Hey giladd,
LINX provies a Digital Write Square Wave function to do this and works with Arduino Uno.  You can learn more about LINX at www.labviewhacker.com/linx.  From there you'll find the getting started tutorial which will guide you throught the LINX setup.
If you have any questions about LINX please post in the LINX Forums.
Thanks!
-Sam K
LIFA and LINX Developer
LabVIEW Hacker
Join / Follow the LabVIEW Hacker Group on google+
(4,684 Views)
What are your pulse width and pulse rate requirements?
hrh1818
(4,684 Views)
width of 10-70 ms(not sure yet) and rate of 15-30Hz
(4,684 Views)
