LabVIEW Interface for Arduino Discussions
vipm msg during installing labview interface for arduino package
(4,662 Views)
You shouldn't be using a 64-bit version of LabVIEW.  The 64-bit version of LabVIEW is made for a very specific puprose which is quite rare.  It also does not support all of the LabVIEW modules and toolkits.
That error is not related to LIFA and is an issue with the connection between VIPM and LabVIEW.  Search online for the error that you are experiencing and you will find some more information.
Also, I'd recommend not using LIFA but using LINX isntead.  LIFA is old and unsupported.  LINX is the new version and can be found at http://www.labviewhacker.com/linx
P.S.  I just did a quick Google search for "vipm could not connect to labview" and got this.
(4,101 Views)
Okay ,, i have solved this problem ,, all things woking correctly now ,,
thank u for ur time ,, Thank you for your interest.
(4,101 Views)
