LabVIEW MathScript RT Module
Can vi's containing mathscript nodes be run on a real time target
I've been trying to find the answer to this question for a while but havent been able to get a solid answer. Can mathscript nodes be used on real time targets?
Jamesponty
(9,141 Views)
Hello Jamesponty,
Currently, LabVIEW MathScript cannot be used on real-time targets.  We are considering adding support in a future release of LabVIEW, but at this time, we have no specific date when it will be available.  For reference, you may find the following documents helpful in determining which features are unsupported on LabVIEW RT targets: https://www.ni.com/docs/en-US/bundle/labview-real-time-module/page/real-time-operating-systems-real-...
Grant M.
Staff Software Engineer | LabVIEW Math & Signal Processing | National Instruments
(9,132 Views)
I have the exact same question.
Now, several years later: Is it possible with the 2012 version?
Would it be possible if I use a *.m file, which I connect via a MATLAB (R) script node? (I have a licensed version installed)
Thanks!
Keks
(7,345 Views)
Well, mathscript is now called Matscript RT and realtime targets are supported. (See also).
What is "it"? Are you trying to run a matlab script node on RT? I think that only works on windows, not RT.
(7,336 Views)
Thank you! 🙂
(7,328 Views)
