LabVIEW MathScript RT Module
Creating new arrays
Hey folks,
 How can I create automatically  array using a loop and a conditional that limits the number of created arrays. I can do this using Matlab, but when I insert the code, LabView doesn't do what I want.
tks
(7,922 Views)
Would you please attach your code?
(7,909 Views)
Your description is not clear enough for us to figure out what you want, either. 😄
In general, LabVIEW can do anything you want if programmed correctly. 😉
Do you want to conditionally built an array, e.g. append new elements, but not necessarily at each iteration?
In this case you would built the array in a shift register and wire actross for cases where the array should stay the same.
(7,900 Views)
Correction - no 3D and beyond N-dimensions in MathScript even with LV8.6 so not everything I guess with MathScript. For example consider stacking 2D arrays on top of each other in MathScript and performing a statistical average - no can do.
Bernardino Jerez Buenaobra
Senior Test and Systems Development Engineer
Test and Systems Development Group
Integrated Microelectronics Inc.- Philippines
Telephone:+632772-4941-43
Fax/Data: +632772-4944
URL: http://www.imiphil.com/our_location.html
email: Bernardino.Buenaobra@ph.global-imi.com
(7,875 Views)
