LabVIEW MathScript RT Module
Data types limitation
In THIS post, I show a small mathscript program (see picture below).
For some reason, it fails with an error if the input array is e.g. I32 instead of DBL.
This seems like an unecessary limitation for such a simple algorithm and should be improved in the next release...
Remember, always wire the error out of the mathscript node! 😉
(8,841 Views)
The sized-integer types (I8, I16, I32, etc.) have a limited set of functionality in LabVIEW 8 MathScript and we are considering improvements for a future release. For now, you can change the data type of your input to double (DBL) as you did in your example, or drop a conversion bullet to a double value before wiring to the MathScript node.
--Sam
Sam Shearman
(8,792 Views)
