LabVIEW MathScript RT Module
Debugging MathScript nodes
I use MathScript probe to debug MS nodes. It's powerful tool, but inconvinient
for monitoring more than one variable. Currently the variables together with
their dimension are displayed in the upper part of the window. If you select
one variable it's contents is displayed in the lower part. It is impossible to
watch  the contents of more than one variable. To improve debugging I have
several suggestions:
1) In case of scalar variables display the value instead of the dimension in
    the upper part of the probe window. This way the values of more than
    one variable can be monitored. Actually, this is exactly the way how
    Matlab presents in variables in the Workspace window.Please note that
    variables of interest are often scalar (e.g. indices).
2) Allow to reorder the variables in the upper part of the probe window.
    This way you can lump all variables of interest together and avoid a lot
    of scrolling. If this is not possible provide an extray Watch window which
    can be populated with variables of your choice (like in LabWindows CVI).
3) If the user select one of the variables please automaticaly adjust the
    data type in the combo box below the variable list. If you currently
    select a string variable the data type is set to 'numerical' by the default.
    So each time you select a string you have to change the data type in order
    to read the string.
4) Another place to present the variable values could be the context help window.
    (like described in the MathScript Nuggest #2). If you hover over a variable
    display the value instead of the data type (or both) in the context help window
    (or alternativly in some tooltip). This is common practice in Mathlab, LabWindows CVI,
    Visual Studio, etc. For me the value is much more important than the data type.
    Particularly as variables can chage their type in MathScript easily.
Ulf Seidel
(8,448 Views)
Hi Ulf,
Thank you for your awesome suggestions! I have filed CAR 194037 to remind us to address some or all of them in a future version of LabVIEW.
In the meantime, there is one existing feature of the probe that you may be interested in: the ability to undock variable views. If you right click on a display in the bottom half of the probe and select "Undock" then the display will pop out into a new window. The new window will continue to update as your variable values change. This is currently the best way to watch the values of multiple values at once.
Thanks again for the ideas. Keep them coming!
jattas
LabVIEW MathScript R&D
(8,440 Views)
Hi Jattas,
thanks for the tip. Undocking the variable view indeed allows
monitoring multiple variables. However, the undocked window
is huge... More than 3 variables are maximum if you still want
to see the frontpanel of your VI.
Ulf
(8,422 Views)
I'm pleased to report that several of these requests have been implemented in LabVIEW 2010. Check out this MathScript Nugget for more information.
Thanks again for the great suggestions!
jattas
(7,908 Views)
