LabVIEW MathScript RT Module
How to call User defined functions in Mathscript Node ?
I have created a user defined function and saved it to Search path of Labview as an M file. If I run my program in Math script window, the function is recognized and the program works properly. If I do the same with MathScript node , the user defined functions are not identified.
Kindly help me with this problem. Thanks in advance
Cheers
Lenord Melvix
(8,145 Views)
