LabVIEW MathScript RT Module
How to insert tab characters for indenting in MathScript Code
Since pressing the Tab key throws one out of Text Mode, when editing a MathScript Node, is there some other way to introduce a tab.  Tabs are extremely handy for improving readability of nested loops and inserting the equivalent number of spaces is time-consuming .
(7,589 Views)
Can you edit the script in the MathScript window (Tools » MathScript Window...)? The tab button works like that from there.
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
(7,570 Views)
That is a good idea but I've already inquired about moving code back and forth between Window and Node.  The only way to do it is to save as a script and then load it into the other, which makes for awkward editing.
(7,566 Views)
