LabVIEW MathScript RT Module
How to solve the plot if shown twice than original data
Dear sir,
I am kunvar yadav, i am using Labview software.
Here i going to plot multi plot in single plot. but the problem is it that i am applying the data of 18 days, but in output result shows data of 36 days.
Here i have attache original file data file and programme.
(6,717 Views)
Use a graph instead of a chart (or run the program only once). Whenever you run the program using a chart, the same data is appended to the chart history, duplicating the data.
(This is a plain LabVIEW question. Why did you post it in the Mathscript forum?)
Many things could probably be done simpler....
(6,708 Views)
