LabVIEW MathScript RT Module
How to write sigmoid equation into formula string in Nonlinear Curve Fit LM?
I am using a sigmoid 4 parameter formula to fit a step-like curve,
The formula is y=y0+a/(1+ exp(-(x-x0)/b))
How to write this equation into formula string in Nonlinear Curve Fit LM?
Thanks for any help.
(8,875 Views)
I suppose that a and b are the unknown parameters. You can add y0+a/(1+ exp(-(x-x0)/b)) in model, add a and b in the array of Parameters and add x in x. Note that you should replace x0 and y0 with the actual number.
(8,835 Views)
