LabVIEW MathScript RT Module
Integer ???
I need to produce a VI that turns on an LCD when an input data is an integer. How do I do this?
(7,262 Views)
Hope it helps
Pelle S
Account Manager
National Instruments Sweden
(7,224 Views)
Pelle's solution is certainly the natural way to do this in LabVIEW. 🙂
  1. You have to be careful though, because if the input is the result of a computation involving fractions, the DBL could be off by a bit or so, leading to unexpected results.
  2. Since you posted in the mathscript forum, could it be you are looking for a mathscript solution?
  3. The current solution turns on a plain LED indicator, but you want to turn on an LCD. Are you looking for a hardware solution to physically turn something on or off? What should be displayed on the LCD?
(7,218 Views)
