LabVIEW MathScript RT Module
Linear control with MathScript
Hi, i'm using MathScript node with Control Toolbox and i'm trying to use LabView in the same way i use MatLab with its Control Toolbox. I would realized a VI with mix of text (in MathScript Node) and graphic program. Someone has used these components and can tell me some suggest to start?
(6,687 Views)
The best way to start looking into this is opening some examples that ships with Control Design Toolkit (or Control Design and Simulation Module, if you have LabVIEW 8.5).
You can find the examples using the Example Finder (go to Help Menu  and choose Find Examples...). Or you can open directly from browsing to: C:\Program Files\National Instruments\<LabVIEW>\examples\Control Design\.
More specifically, the example \Getting Started\Mathscript\CDEx Loop Transfer Recovery for Satellite Attitude.vi gives you an idea about how to use the "hybrid" mode (text + graphical).
Hope this helps!
Barp - Control, Simulation, RTT and HIL - National Instruments
(6,677 Views)
