LabVIEW MathScript RT Module
Loading MAT data files
I am using Mathscript window to load MATLAB mat-file.  After the confirmation of when the file is loaded, I find the variable src1 to be empty.  It should contain a field of data.  I have attached the dta file for your evaluation.  Please advise what I am doing wrong.
Duc
(7,726 Views)
Hello Duc,
Unfortunately, your .mat file contains a structure, which LabVIEW MathScript does not currently support.  We are aware of this limitation and hope to offer support in a future version.  As a workaround, you can save your data as separate variables instead of a cluster (e.g. src1_RangeMin, src1_RangeMax, etc.)
Grant M.
Staff Software Engineer | LabVIEW Math & Signal Processing | National Instruments
(7,714 Views)
Hello Grant,
Thanks for the reply.  Unfortunately, I can't change the format of the data files.  Is there a method I can open the mat-file in the LABVIEW environment, maybe to use a different option to Mathscript?
Thanks in advance,
Duc
(7,701 Views)
