LabVIEW MathScript RT Module
MathScript/LabVIEW residue bug
Try this in MathScript:
>>bb = [6 -8];
>>aa = [1 -1 -6];
>>[r,p,k] = residue(bb, aa)
r =      4
           2
p =     -2
           3
k =      0
Then multiply both the numerator and denominator by z:
>>bb = [6 -8 0];
>>aa = [1 -1 -6 0];
r =      -8
           6
p =     -2
           3
k =      0
Wow, you get a different, wrong answer.  Matlab returns the same answer in both cases.
Take this a step further and use the Partial Fraction Expansion VI.  It gives the same wrong answer!
What's up?
(9,295 Views)
Further investigation shows that the error in in the Partial Fraction Expansion VI which is called by residue.vi.
--Mark
(9,292 Views)
Hi Mark,
You've located a problem with the LabVIEW MathScript function 'residue'.
With your example
>>bb = [6 -8 0];
>>aa = [1 -1 -6 0];
the problem arises when the parameters bb and aa describe polynomials that are multiples of 'z' and have a nontrivial greatest common divisor:
bb represents 6z^2-8*z
aa represents z^3-z^2-6z
As you noted, the problem occurs due to an underlying problem in Partial Fraction Expansion, a VI from the LabVIEW function palette (Mathematics->Polynomial->Rational Polynomial) that is being called "under-the-hood" when you invoke the LabVIEW MathScript 'residue' command.
One way to avoid this problem is to do pole-zero cancellation before applying 'residue'
Alternatively, you can perturb aa or bb slightly by adding some small constant terms, for instance:
>>bb=[6 -8 1e-6]
The problems described here are something that our engineers are aware of and are planning to fix in a future release.
--Sam
Sam Shearman
(9,254 Views)
