LabVIEW MathScript RT Module
MathScript RT Module internal error
Hi
Just for the fun of it I wanted to try out the MathScript RT Module. Use it to make some plots. So I made a small vi that reads some arrays into LV and plot them in Labview and also in a figure window. This worked ok for a couple of days, but when I opened LV today I couldn't run the vi, and LV suggests that I reinstall MathScript RT Module......................hmmm. As soon as I removed the Mathscript window the vi run fine. Have anyone experienced somthing similar?
I'll try to reinstall Mathscript.........but what's going on?
(7,301 Views)
Have you built any applications with MathScript?  If so, that may have corrupted some internal files.  Try shutting down LabVIEW and deleting your "My Documents\LabVIEW Data\InstCache" folder.  If you have not built any applications, can you attach your VI so we could take a look at it?
Grant M.
Staff Software Engineer | LabVIEW MathScript | National Instruments
(7,242 Views)
Hi Grant
Nope, I just wanted to try out plotting af few figures. I reinstalled the Mathscript RT module and now everything works again. I'll let you know if the same problem occurs again.
(7,235 Views)
