LabVIEW MathScript RT Module
Mathscrip VI shows inconsistent speed on different PCs?
VI containing mathscript shows different speed on different PCs. I doubt on some setting of LabVIEW componets. What could be the reason?
(6,620 Views)
It could be several things. What version of LabVIEW are you using? Is it the same on both machines? Do you have the same add-on software installed and activated? Specifically, MathScript has a tight relationship with the Control Design and Simulation Module. If one machine has it but the other doesn't, that could be a cause.
What kind of speed differences are you seeing? Is it the time to run a MathScript Node? Or a script in the MathScript Window? How much slower does it get?
jattas
LabVIEW MathScript R&D
(6,609 Views)
