LabVIEW MathScript RT Module
Mathscript RT module is not working in LabVIEW 2012
Hi All,
I have recently installed LabVIEW 2012 in my PC with Windows 7. However, Mathscript is not working at all. It says "An internal error has occurred in the MathScript RT Module.  Restart LabVIEW and try again.  If the error persists, reinstall the MathScript RT Module." I did that but still does not work. It further says that Mathscript is missing or not installed" but I have installed it. What could the problem be, please?
Message 1 of 22
(17,204 Views)
Are you installing the module with an installer you downloaded or from disk? You can download the software on this page:
https://lumen.ni.com/nicif/us/evaltlktsigproc/content.xhtml
You will need to unzip and install for your current LabVIEW version. Have you also activated this module? If you check under LabVIEW 2012 and then Modules in NI License Manager (Start>>All Programs>>National Instruments>>NI License Manager), do you see the MathScript RT Module listed and colored green? It should also say "Activated for this computer" on the right panel when selected.
If the module does show as activated, can you post more info on the behavior you are seeing? When exactly are you getting the error mentioned? Does it show up when opening LabVIEW, dropping a MathScript Node, executing code with a MathScript node in it, etc?
Zach P.
Staff Software Engineer | LabVIEW R&D | National Instruments
Message 2 of 22
(17,171 Views)
Also, are you using 32-bit or 64-bit LabVIEW?
Message 3 of 22
(17,166 Views)
It comes when I open a Labview program that uses mathscript.
Message 4 of 22
(17,160 Views)
Accepted by topic author devkotaj
Were you able to check the installation and activation in NI License Manager? It should say Activated for this Computer and have a green square like this:
Zach P.
Message 5 of 22
(17,146 Views)
I am using 32 bit LabVIEW.
Message 6 of 22
(17,141 Views)
I don't see the mathscript activated in the list.
Message 7 of 22
(17,138 Views)
Is MathScript Node listed in License Manager at all or is it missing?
If it is in the list, what color is the box and what is its status? You need to activate MathScript with your serial number. If this does not work, verify that your serial number includes a license for MathScript by contacting your NI Account Rep at (888) 280-7645.
Contact NI
If MathScript is not in the list, it is not installed for LabVIEW 2012. You can find the installer at the link in my first post.
Zach P.
Message 8 of 22
(17,125 Views)
Hi guys, excuse me but, I have a little problem, I use Labview 2012 64 bit, I downloaded MathScriptRT for this pack, but, when I want to installed, send me a message that I have to installed Labview 32 bit, why happend that? Could you help me? please
Message 9 of 22
(17,089 Views)
AFAIK, Mathscript is 32bit. Is there any reason you are using 64bit LabVIEW?
Message 10 of 22
(17,084 Views)
