LabVIEW MathScript RT Module
Mathscript loading .mat files leaves no variables
Have problems loading either .txt ( ascii, double tabs) and .mat files into Mathscript command window or script window.  Get consistent error messages that I need Dataplugins...have downloaded every thing I can find and nothing helps.  If the .mat appears to load it says Mat 5.0 and leaves no data variables in the workspace.  Also get error message about GBIP not present,what does that have to do with anythink?
Any ideas are warmly welcomed,
CEK
Message 1 of 9
(11,068 Views)
Hi Cek,
MathScript is unable to load .txt file directly. For .mat, only those saved with -v6 option can be loaded into MathScript. Note also that only the variables in 2D array can be loaded. Currently, MathScript does not support structure or cell array.
If you can attach your .mat file, I can look into the problem.
Message 2 of 9
(11,065 Views)
Great here is a typical .mat file
I appreciate the help,
CEK
Message 3 of 9
(11,052 Views)
Hi Cek,
When I tried to load your .mat file, I got the following head information.
MATLAB 5.0 MAT-file
Platform: MACI
Created on: Sat Mar 22 09:00:11 2008
It seems that MathScript can not recognize the MACI platform and returns nothing. I do not know what's the meaning of MACI. Maybe Mac Intel, I guess. Anyway, I will report this problem.
The workaround is to change the platform to MAC2. You can modify the .mat file by any text editor, such as Notepad++. MathScript can read the .mat file with platform MAC2. I tested it and got a 442-by-512 double array from your file. You can find the modified .mat file in the attached archive. Please try and validata it.
As to the .txt file, MathScript support the function textread. If it does not work, you can try fread. I can also look into it if you can provide a sample file.
Feel free to let me know if you encounter any problems.
Message 4 of 9
(11,041 Views)
HI ttrr,
I now am using a workaround to avoid needing to load .txt or .mat files, by switching over to .tdms files logges via SE.  This is much cleaner.  But thanks for your advise.
CEK
Message 5 of 9
(11,024 Views)
Hi Cek,
It is great to hear that you have a workaround for this problem. MathScript is also able to read and write TDM(S) file.
Would you please do me a favor to verify whether MACI means Mac Intel and the correctness of data loaded from MathScript? Thanks in advance!
Message 6 of 9
(11,018 Views)
Hi ttrr,
yes the modified mat file reads in perfectly.  Thanks, your time, efforts, and skills are appreciated.
cek
Message 7 of 9
(11,001 Views)
Hi ttrr,
Yes I am using a Imac, Intel running XP under Bootcamp/VMfusion.  And yes the data is correct.
cek
Message 8 of 9
(11,000 Views)
Hi Cek,
It sounds good to me. Thanks!
Message 9 of 9
(10,993 Views)
