LabVIEW MathScript RT Module
Sparse matrices
Does Mathscript feature any type of sparse matrix operations (perhaps one of the most powerful matrix features of Matlab)?
2006 Ultimate LabVIEW G-eek.
(8,426 Views)
Unfortunately, LabVIEW MathScript does not provide support for sparse matrices at this time.  We are considering the possible inclusion of sparse matrix support in a future release.
Grant M.
Staff Software Engineer | LabVIEW Math & Signal Processing | National Instruments
(8,408 Views)
if you're tried making an .exe from a vi with a Mathscript node with Application Builder 8.2,
you discovered that (surprisingly) the Mathscript node is being converted to G code.
This was particularly obvious when I made a simple executable that ran
a modified Cholesky algorithm in the Mathscript node. Numerous linear algebra vi's
that were not on the block diagram were included in the slow build.
So, for Mathscript to support sparse matrices, LabVIEW will probably have to support
sparse matrices first. I imagine they are working on it as we speak.
But in the interim, attached is a first start:  a tri-diagonal matrix solver
using the fast Thomas algorithm.
(7,839 Views)
