LabVIEW MathScript RT Module
The output of my mathscript node is not changing the data type ?
hi
iam attaching my .vi iam having problem that my math script function is not changing it data type in its output
iam uisng labview 2009
what reason it will be?/
thanks
Message 1 of 8
(9,809 Views)
Can you clearly post what exactly you want to do...
Smiley Wink
Message 2 of 8
(9,800 Views)
If you are sure with the c coding try using this...
Smiley Wink
Message 3 of 8
(9,794 Views)
Not sure how that's supposed to help since the code is MathScript, which is a different language...
For original question: Have you verified that the license for MathScript is active? You can do this through the NI License Manager (Start -> Programs -> National Instruments -> NI License Manager). For LabVIEW 2009 MathScript is licensed as a separate product - it is no longer bundled with LabVIEW.
Message 4 of 8
(9,770 Views)
First off, there is a dedicated mathscript forum that might be better to get your problems answered. (I see if I can have this thread moved from the LabVIEW board, else you can re-post over there.)
I see the same problem that (1) the outputs have no datatype and (2) all datatypes are greyed out, so they cannot be selected manually. (The input is trivial, just wire something and it will adapt).
I am not a text programmer, but I suspect that there is something wrong or incompatible with your code. I have not looked at the statements. Is this copied from an existing matlab program, for example?
Message 5 of 8
(9,759 Views)
It's probably a continuation of this thread
Message 6 of 8
(9,751 Views)
thanks all
i knew mathscript have user defined funcion but not 100 similar like matlab
iam trying to change code
tc
Message 7 of 8
(9,719 Views)
Hi Nabeloabbasi
A couple things concerning your code:
1. The 'x0' input needs to have something wired to it so the compiler can use its data type to compute the data types of everything that depends on it. This means you will have to create a control or constant and wire it to the 'x0' input terminal on the MathScript node.
2. There is a 4th terminal on the right hand side of the node 'uk' that is currently marked as an input terminal. Based on your code I would guess you meant for this to be an output terminal but if not then you would need to wire something to this terminal as well.
Changing these two things will allow MathScript to automatically select the data types for the output terminals.
K Scott
Message 8 of 8
(9,601 Views)
