LabVIEW MathScript RT Module
Variable Substitution in MathScript
how is it possible in MathSkript to substitute a variable with the actual value in an expression?
To be more specific, I want to do in principle the following:
% this works
f='x+y'
ezsurf(f)
% then I want to multiply y by a factor
scale=100
f='x+y*scale'
ezsurf(f)
% which then fails.
Any advice is highly appreciated!
Thank you
Peter
(7,100 Views)
For ezsurf, it is unable to specify external variable. The workaround is that
1. Hardcode the variable with the actual value, e.g.
    f = 'x+y*100'
    ezsurf(f)
2. Format the input string for ezsurf, e.g.
    scale = 100
    f = sprintf('x+y*%f', scale)
    ezsurf(f)
Let me know your special requirement.
(7,091 Views)
thank you for the reply. I could solve my task with your suggestion.
Best regards
Peter
(7,087 Views)
