LabVIEW MathScript RT Module
What is the way to declare a string array?
Doesn't Mathscript  allow curly brackets in its syntax?
What should be the syntax to define a string aaray?
for example
alpha = {'abc', 'def', 'efg', 'hij'};
Message 1 of 8
(8,394 Views)
Does this link help you?
Message 2 of 8
(8,374 Views)
Is this a valid link? I'm not able to open this..
Message 3 of 8
(8,360 Views)
Message 4 of 8
(8,359 Views)
Have you tried the same syntax as in MATLAB?
Message 5 of 8
(8,335 Views)
Yes.
Message 6 of 8
(8,325 Views)
Hi intersteller,
The curly bracket syntax is used to define cell arrays which MathScript does not currently support. It is possible to define an array of strings as follows: myarray=['abc';'def';'ghi'; etc...] but each element (string) is required to be the same size in a standard array. I imagine that would be very inconvenient for you. You might consider trying to modify the function that accepts the cell array to operate on a single string and then call the function multiple times.
K Scott
Message 7 of 8
(8,318 Views)
Hi Scott,
Wont it work if the element required is of different size?
for example: myarray=['abcde';'fgh';'i'; etc...]
Message 8 of 8
(8,306 Views)
