LabVIEW MathScript RT Module
clearing matlab data
I am having a problem running matlab scripts in Labview 7.1. The program only gives the correct result the first time I run it then gives a wrong results the next time with only very slight changes like adding outputs which I know wont affect the program as a whole. I tried to run the script in Matlab and it works well. Can anyone help me how to clear the previous data? Is a limitation of matlab script in labview? Thanks
(6,585 Views)
Howdy,
Can you post your code? What version of MATLAB® are you running? What are you needing to accomplish?
MATLAB® is a registered trademark of The MathWorks, Inc. Other product and company names listed are trademarks and trade names of their respective companies.
Joshua B.
(6,574 Views)
