LabVIEW MathScript RT Module
conversion from double to integer
I have may be a stupid questio.
I have a double array, it is an input of the Mathscript, the first two column's  elements like : 1.0000, 2.000, ...etc. I would like to conversion it from double to integer, because I'll use it to index an other array. When I run the VI, I get a run time error. It seems the explicit conversion is not working. In Matlab I can conversion data types on the same way.
Error code -90026 matrix index must be real, positive integer
My code can you see on the picture below.
Please help!
(7,643 Views)
Accepted by topic author Tamas
I solved the prob
I started indexing to 0 and not to 1. that occured the problem.
(7,627 Views)
