LabVIEW MathScript RT Module
difference between mathscript and matlabscript
hi iam new to labview and learning  n doing project on labview
what is the difference between mathscript and matlabscript
i want do simulation using matlab
how can i do
if any one suggest this
please reply and give some support so that i will complete my project........
(15,291 Views)
Accepted by topic author paar
With the LabVIEW MathScript Node, the blue rectangular region, you can run .m file scripts from your LabVIEW graphical programs (known as virtual instruments or VIs). You can use the MathScript Node
to insert textual algorithms into a VI and then use the LabVIEW graphical programming environment to instrument the scripts by adding knobs, slides, buttons, graphics, and other user controls and indicators.
(15,257 Views)
(15,256 Views)
To understand Developing Algorithms Using LabVIEW MathScript, browse through the following link:
http://zone.ni.com/devzone/cda/tut/p/id/3257
(15,255 Views)
than sir
sir can u tel me how can we do simulation using math script or matlab node
figure should simulate on waveform graph or chart
for example amplitude Vs Frequency of the system......
if u want i wil send my VI having matlab code......
(15,221 Views)
From reading the responses I do not feel the answer to the original question was really answered. "What is the difference between the Mathscript node and the MATLAB node?"
One major difference is that the Mathscript RT add-on module node does not require you to have a licensed version of Matlab installed and it handles the script within the VI . The MATLAB script makes a separate call to MATLAB to process the script and requires a licensed installation on the local machine.
(14,215 Views)
It's frustrating when people don't read the question and then answer what they know, instead of what the OP asked.
Thank you for catching this, and exactly answering what I and the OP wanted to know.
(11,689 Views)
