LabVIEW MathScript RT Module
does the command size from matlab is supported in labview mathscript
hi, im using the labview mathscript and i want to create my own function, my code has the command []=size();
when i run the script in the window labview mathscript it shows the error "expecting EOF, found '['" in the
line where i have the command size
Can somebody help me?
grettings
(7,361 Views)
Hi, What do you want for run command []=size()? Usually, you should use c = size(a) or [m, n] = size(a). http://zone.ni.com/reference/en-XX/help/373123C-01/lvtextmath/msfunc_size/
(7,348 Views)
hi, yes i already saw that link, i tried on:  [m,N,ntrials]= size(X)
and i cant see the mistake
(7,346 Views)
Currently, MathScript does not support mulit-dimensional array. That is to say, size can have two outputs at most.
(7,342 Views)
hi, you were right thanks
(7,333 Views)
