LabVIEW MathScript RT Module
echo cancellation using deconvolution
Hi! I have a signal with echo y(t)=x(t)+a*x(t-τ).
I need to remove the echo usign deconvolution, so rewriting this equation
 y(nΔ)=x(nΔ)*(δ[nΔ]-aδ[(n-N)Δ])=x(nΔ)*h(nΔ)
Where Δ is the delay time and a is the amplitude of the echo. Then x=deconv(y,h)
Please, how I can do it on the mathscript node?
(6,465 Views)
Have you checked out this? http://www.ni.com/white-paper/7572/en/
I not entirely familiar with the MathScript Module, but that should be good start. (Also a couple developer links at the bottom.)
(6,427 Views)
Hola master45,
I notice some similar forums opened by you for the same inquiry. I suggest continuing the conversation here, so we can help you more effectively following your questions about this application.
Help with mean filtering and noise reduction with Mathscript, Noise reduction using mean filtering with mathscript hybrid programming, cancelación de eco usando deconvolución y mathscript.
Try to navigate the forums' topics and post your question in just one thread Smiley Happy
You can find the deconv function under the polynomials class of the MathScript functions. I suggest checking how it works so you can implement it in your solution. Also, if you can be more specific in the step you're having trouble with it, can be easier for the community to help you out.
Keep us updated. Kind regards!
(6,420 Views)
