LabVIEW MathScript RT Module
erfc and erfc_inv not recognized in labview communications design suite
I have installed MathScript RT module and I am working on a mathscript node which I want to implement an algorithm.this algorithm contains the Q function which unfortunately don"t exist on labview so I have switched to the erfc function but still don"t work also.Any suggestions please ?Capture3.PNG
(6,971 Views)
HI,
I saw that you already posted this question here
and that you should change your function node to C.
Did this solve the problem?
Best,
Anna
Anna Vogl
Certified LabVIEW Developer
(6,945 Views)
for the erfc function it worked but i need the erfc_inv which it don"t exist besides I have problem also with defining my output.
Do you have any other suggestions please.
Thanks.
(6,939 Views)
there is indeed no inverse error function in the analysis library list.
But there is a LabVIEW VI: "Inverse Error Function Complement VI" if that helps you.
What problems do you have with defining your output. Could you be more specific please?
Best,
Anna
Anna Vogl
(6,928 Views)
Actually I am not working in labview, I am working in labview communications design.So this VI doesn't appear in my library.
(6,908 Views)
