LabVIEW MathScript RT Module
fread_xls
Hi! 🙂
I'm working on a project which deals with making of Prosthetic arm. I'm using an NI ELVIS - II to take signals from my muscles on analyse the voltage using MATLAB. I've the MATLAB code with me. But, when transproting it into the LabVIEW Mathscript I'm encountering a certain problem.
How to take voltage samples from an excel sheet as an input in the Mathscript environment. In MATLAB editor, I used 'xlsread' function. I tried using fread_xls but I was enoucntering an error
Kindly help me resolve this issue
Thank you in advance
(6,244 Views)
What error did you encounter? Which syntax did you use? Could you attach your excel file?
Please give more information about your problem.
(6,238 Views)
