LabVIEW MathScript RT Module
Showing results forΒ
Search instead forΒ
Did you mean:Β
how to enter mathscript syntax command as per below equation
Signal g(t) is defined as: 𝑔(𝑑)= 3(𝑑+2)𝑒(𝑑+2)βˆ’ 6(𝑑+1)𝑒(𝑑+1)+ 3(π‘‘βˆ’1)𝑒(π‘‘βˆ’1)+ 3𝑒(π‘‘βˆ’3)
a) Sketch the signal completely. (3 marks)
b) Using MATLAB, plot the signal g(t). (10 marks)
c) Signal g(t) then undergo an operation below:
2g(t + 3)
Plot the new signal 2g(t + 3) using MATLAB.( im trying to do it using mathscript )
Message 1 of 1
(4,724 Views)
