LabVIEW MathScript RT Module
how to plot 2 arrays on a graph in labview communications design
Actually, I am trying to plot 2 arrays from the mathscript node .one depends to the other.I have made a cluster for the 2 arrays and plot them in the graph but the resulted graph doesn't really show the exact values.
I want to plot pde_sim which depends on snrdb.
the resulted figure that I get is :
Is something wrong with my code ??
(6,647 Views)
Accepted by topic author emnajaoua
You need to use Build Cluster instead of Build Cluster Array.
(6,640 Views)
