LabVIEW MathScript RT Module
image reconstruction
I'm trying to use mathscript to reconstruct an image, original file is a 16 by 16 bitmap file, in matlab I can use gray(256) function to convert the bitmap file into gray code image, but how to realize this in mathscript?
(6,671 Views)
What does the reconstruction mean?
Currently, MathScript does not support the gray functions. However, a bug report has been filed for the unsupported colormap function. You can find detail in this thread.
To display a image in gray code, you can use the following script
image(A);
colormap('gray');
where A is the image data.
(6,660 Views)
