LabVIEW MathScript RT Module
mathscript will not compile - apparently prevented by use of a for loop
Using LabVIEW 2009 I can get the MathScript [1]:
A = 1
for i = 1:1:10
A = A + 1
end
to compile just fine.  After upgrading to 2009 SP1 (and also after applying the f3 patch and then upgrading to SP1) the same MathScript no longer compiles, however the script
A = 1
%for i = 1:1:10
A = A + 1
%end
will compile.  To test this I create a new VI in whichever version of LabVIEW I'm using and write the script from fresh - not copying or pasting from a previous file version.
The same behaviour is replicated in the built-in example "Mathscript Fractal.vi" - it only compiles for me when the for loop is commented out.
I've tried the steps suggested in http://digital.ni.com/public.nsf/allkb/DD220B71245A391E86257720007E1FE8.  I don't detect any corrupt instantiations using the provided executable.
Any suggestions welcome...
Andy
[1] example in http://zone.ni.com/reference/en-XX/help/373123B-01/lvtextmath/msfunc_for/
(6,210 Views)
Hi AndyBI,
You mentioned upgrading LabVIEW 2009 to 2009SP1 but did you also upgrade MathScript to 2009SP1? This is a common cause for problems since MathScript 2009 is not compatible with LabVIEW 2009SP1.
Cheers,
K Scott
(6,204 Views)
