LabVIEW MathScript RT Module
problem with analysis, modifying and storing a real time signal
I have to analysis a real time signal. I have acquired signal properly. Now I have to do three major things---
1. I have to change the time axis into deg. the relation b/w these two is like that
                                                      deg. value, say, D=t*5000*75                          t is in sec.
         and then have to plot the signal against this D
2. Now I have to store the signal values in Excel file.
3. I just have to plot only one cycle of this signal and have to stop the program automatically just after plotting one cycle of the signal. (I think, as it is a real time signal nothing but comparing the amplitude can help to detect the completeness of the cycle.)
Please help me to solve this problem.
(6,549 Views)
Your question has little to do with Mathscript. Are you trying to use mathscript to do all that??? 😮
I would recommend to use plain LabVIEW. You should repost this question on the LabVIEW Board.
(6,545 Views)
