LabVIEW MathScript RT Module
some strange behavior
I have found something in mathscript that I can't quite figure out.
If I define the following:
N = 8192
fs = 1.92e9
and then generate
t = [0:1/fs:(1/fs*(N-1))]
I get a array that is only 8191 long instead of 8192 which is what matlab gives me.
What is more strange is that if I set N = 1024 then mathscript does in fact give me a 1024 elements. In fact every number I tried around 8192 gave the right result. When I change fs to something else I get the right number too. There is something to the relationship of fs to N which creates a special case that causes a drop of the last element?
Jeff
(7,623 Views)
I can reproduce this and think it is a bug. I have reported it in the general bug thread:
Hopefully somebody from NI will throw in a comment and possibly provide a CAR#. 😉
(7,601 Views)
Hello Jeff,
You have discovered a bug in MathScript.  I have filed a CAR (#45TCCISF) and it should be fixed in a future release of LabVIEW.  It looks like MathScript is only omitting the calculation of the last element and this is likely a rounding issue.  For a workaround, you could manually compute the last element and append it to the matrix.
Grant M.
Staff Software Engineer | LabVIEW Math & Signal Processing | National Instruments
(7,593 Views)
