LabVIEW MathScript RT Module
traité une image par matlab script sur Labview
Hi thanks for your reply. I have done that already. There was no reply. I thought this was similar to my problem. My problem is that, i need to call a .m file from matlab to labview. In that .m file I need to read a Image which I wasnot able to do so. could you please help me with this.
Message 11 of 19
(9,723 Views)
Hi !!
firstly i suggest to delete the instructions clear all and close all from Mathscript node because you enter your variable before the "clear all" so you clear all the variables in the mathscript and then its gives you an error of the variable  no existing . ok try this and if there is other problem send us your program and we will try to help !!
good luck
Message 12 of 19
(9,715 Views)
Hi, Thanks for your reply. I have taken out  clear all and close all from mathscript in mathscript node.(We can see errors when user functions are used in the mathscript). But I wasn't able to read image even though when I had converted the image into 2 dimensional array. Here I am attaching my file. Thanks in advance.
Message 13 of 19
(9,707 Views)
Iam working on GUI on Labview and also MATLAB image processing. I want to integrate a MATLAB image on real time basis in Labview. Through MathScrpit iam able to do it but then the image is popping up as a result. I want the image to be integrated in my GUI. Please guide me in this area.. Waiting for help..
Have a good day!!
Message 14 of 19
(9,553 Views)
This looks like a new problem and you should have started a new thread. Can you show us some simplified code?
Message 15 of 19
(9,548 Views)
It can be any code which produces image as ouput. Right now iam working on a dummy matlab program. My LabVIEW GUI is divided into half, it shows two windows, One will show the live camera and the other will show the matlab image produced by image processing in GUI. iam done with the fetching of live camera, and exactly on its right i need to place my matlab window.
Help required!
Message 16 of 19
(9,540 Views)
Hello..
I read your replies about matlab script node for images. I am a beginner for labview and myrio. I want to use matlab script node for manipulations of image,and I want to dump the code in myrio kit and see the result.I am facing the problem as during dumping the code,the error pops up as matlab script node not supported by myrio.Can u help me regarding this?
Thank you
Purva
Message 17 of 19
(7,267 Views)
Hi Purvap,
The Script Node itself calls MATLAB® software to execute the script. The myRIO is a Real-Time target, so you cannot install MATLAB® on it, and therefore cannot execute the Script Node. This is likely why you are receiving the error. Try using the LabVIEW MathScript RT Module instead!
http://www.ni.com/labview/mathscript/
Also, it looks like you had already been addressing this issue on another forum thread. Perhaps continue to post there as well!
Ross S.
Applications Engineering
Message 18 of 19
(7,253 Views)
Thanks a lot DaSage. I will try using Mathscript RT module 🙂
Message 19 of 19
(7,234 Views)
