LabVIEW Project Providers
Valid values for CreateNewWizardHost?
What are valid values for CreateNewWizardHost (a parameter in the GProvider INI file) other than Build and Source?
(5,483 Views)
Hey Jack,
As far as I know, these are the only two supported values.  Is there somewhere else you'd like to add a New Wizard host that isn't supported by either Build or Source?
David
(5,449 Views)
This is part of a larger investigation on the capabilities of Project Providers and the ability to create more 'fundamental' ProjectItem types -- more details here: https://decibel.ni.com/content/thread/17342
A third option that I'm interested in is Root (in addition to Build and Source) that could hook into the New... menu of the Root:
(5,449 Views)
I just found out that "System" is also a valid value for CreateNewWizardHost. It seems to be adding an entry at the top-level as in your screenshot above, but exactly how the item added behaves I am not sure. I will try to find more information on this, meanwhile I thought I will share this and see if this works for your use case. Hope this helps.
Sumedha
Sumedha Ganjoo | LabVIEW Product Manager
(5,449 Views)
Specifying CreateNewWizardHost=System looked quite promising and got me super-excited:
And then, the new item was created inside My Computer 😞
Any ideas on how to get a "top-level" or "root-level" item such as this?
By the way, even though it's one step forward one step back, I'm excited to be building on this tribal knowledge of Providers and *really* appreciative for the research you're doing.
(5,449 Views)
Agh! Sorry about that.
We haven't yet found a way to do this using providers, but we will keep investigating and let you know if we find anything.
Likewise! Thanks for all your work and research with the providers, it's helped us expand our knowledge of the framework as well
Related to your original question, another value that we found is valid for CreateNewWizardHost key is "FileNewDialog".
All credit goes to David for concluding correctly that this must be adding a new item to the File -> New Dialog.
Sumedha
(5,449 Views)
That's fantastic! You've doubled the number of known values in a few days! 🙂
CreateNewWizardHost can be: Source, Build, System, or FileNewDialog
(5,449 Views)
