LabVIEW Public Beta Program in 2024
New Open VI Reference Functionality
Per LabVIEW 2024 Q1 Features and Changes, Open VI Reference can now accept a VI reference for the vi path input.  I took a vim I use for calling reentrant VIs and started to play with this new feature.  With this new feature, I was able to eliminate a property node from my vim (getting the VI's name).  I wired a strict typed static reference straight to the vi name input and left the type specifier unwired.  I saw my VI type properly propagate, even allowing me to wire up a Start Asynchronous Call.  But I got error code 1026 when I ran the code at the Start Asynchronous Call.  The Open VI Reference just returns a Not A Reference and no error.  The fix was to wire up the type specifier as well.  But this just seemed strange that if I am giving Open VI Reference a strict typed static reference for the path, why do I also need to tell it the type in order to get a runtime reference?  And if this is by design, why am I not getting a compile time error?
Attached is my code for reference.
Message 1 of 16
(4,704 Views)
It's a bug. The type propagation is intending for this to work. Unfortunately the execution code is creating a non-strict reference so we end up with a non-strict reference on a strict reference wire.
Workaround is to wire the input reference to the type input as well, like you did.
Message 2 of 16
(4,667 Views)
To get a strict type from Open VI Reference, type has always been required. So I guess this behavior would be a nice to have. Of course if it compiles it should run.
So what if you don't want a strict type from the strict reference?
Is it harmless to simply ignore the strictness....?
Is there any penalty (e.g. performance) for getting a strict type when you want a normal reference? Because AFAIK it's impossible to go from a normal reference to strict type...
Message 3 of 16
(4,435 Views)
1. Use a non-strict constant to the type specifier.
OR
2. Just use a non-strict from the beginning
It just makes sense to me that if you wire a reference to the VI Path, the output should match the reference type (string or non-strict) by default.
Message 4 of 16
(4,428 Views)
I just saw that 2024Q1 Patch 1 dropped on Friday.  This bug (2643576) is on the list of bug fixes.  I'm installing it now and anxious to test it out.
Message 5 of 16
(4,349 Views)
Attached is my updated example with 2024Q1 Patch1 installed.  It works perfectly.  This update is going into my reuse library.
I know this is a small, possibly niche, feature, but it is one of the small things that does make things a lot simpler.  Good job on this, NI.
Message 6 of 16
(4,344 Views)
The strict type seems to work for me.
More importantly, if the type isn't wired, Open VI Reference does not wait for a free root loop!
In <24Q1 this hangs when a menu is activated:
It's the only way to get a strict type reference.
This doesn't wait for the root loop, but it's not a strict type (e.g. no Call By Ref, Call And Collect\Forget), the alternative, Run VI method, also needs a free root loop...)
In 24Q1, this still needs a free root loop:
But this doesn't!!
This is a HUGE win!
Also see Re: What am I doing wrong with asynchronous call and forget? - NI Community
Message 7 of 16
(4,212 Views)
But this doesn't!!
This is a HUGE win!
Now try it with an option flag wired up to the Open VI Reference.  I'm seeing the "freeze" at the Open VI Reference if I have a menu open.
Message 8 of 16
(4,205 Views)
But this doesn't!!
This is a HUGE win!
Ah, I see, so that's the bug they are going to fix!
Hopefully we end up with this bug fixed and no free root loop requirement. 👍
For NI:
This free root loop dependency is simply programmer's hell. There's really no way to win. Strict type: can't open, no strict type: run method hangs. This should be easy...
Once this new Open VI Reference functionality works, please have a look at fixing this for the Open VI Reference by name\path.
Message 9 of 16
(4,203 Views)
The bug mentioned above was fixed with the patch:  the strict type reference works at run-time now.  So what you are seeing with the root loop is likely an artifact of the strict type reference not being passed properly at run-time before the patch.
Message 10 of 16
(4,201 Views)
