LabVIEW Public Beta Program in 2023
top of a front panel window [OSX]
The top parameter of the windows bound changed with LV23
If we want to stick to the menu bar,
In LV22 the top of a front panel window had to be set to 37
Now in LV23 the top of a front panel window has to be set to 24
Do we have to change all the settings of the VIs made for LV22 or does this is a bug that you are going to correct ?
Thanks in advance
(2,150 Views)
I wondered why a new VI would suddenly move up into the menu bar being covered by a few pixels.  Hopefully this will be fixed in the next release.....
LabVIEW ChampionLabVIEW Channel Wires
(2,124 Views)
Thank you for reporting this issue! I've filed Bug 2418331 to track it.
Christina Rogers
Principal Product Owner, LabVIEW R&D
(2,105 Views)
