It would be nice if LabVIEW RT could give more output during the startup process of a LabVIEW real-time executable. For example if the rtexe is started at all or not, if there are missing dependencies during the loading process or other usable stats.
In my case I had problems with the German codepage. The build process was done without failure. But the rtexe didn’t start at all. I used special German characters like “öäü” in some VI names. And the rtexe couldn’t be loaded for that reason. But I didn’t get any message.
So please improve the debug output for LabVIEW RT.
