It would be nice to had the ability to create more than one RT target in a project with the same IP address.
For the moment, if you try to use 2 same IP address, The LabVIEW IDE don't let you save your modifications ! ![]()
You may say WTF !!!! The manu has so curious ideas !!!!
My need is for example to had 2 configurations for 1 only RT CRio.
Or an other way to use multiples targets ...
Yopu may say this can be done by using different build specifications.
I will say yes ... But my need is to separate the two versions of LabVIEW sources !
=> 1 project/target linked to an autopopulating folder in version a
=> 1 project/target linked to an autopopulating folder in version b
=> So my need is to be abble to use RT Targets as "Target versions"
=> To be abble to do this ... i need to create multiple targets with identical IP addresses. ![]()
Thanks for reading.
Manu.
