Has anyone ported a real-time VI originally targetted to cFP to install on cRIO?
I have an older control program, main VI and subVIs built in LV 8.6 and run on a compact FieldPoint controller.
I would like to be able to use much of it on a cRIO-9036 or something similar.
I am wondering whether LabVIEW (2015 or so) will do the work for me.
Thanks in advance.
