I am often working with a compact RIO and I need to change the IP configuration or the software settings. Currently I have to open up MAX refresh my target list (which can sometime take a minute or two since we have so many targets). Then open up the RT target settings.
I think the IP address and software settings should be accessible from the project window by right-clicking on the target and selecting properties.
The MAX settings page could be reproduced in the general settings section that all ready has a limited ability to edit the IP.
You could also add a  software category, so you could update the version of RIO or install scan engine.
